Learn how to 3D print your own Obsidian block from minecraft and add colorful RGB LEDs powered by the EDU PICO. Simple, fun, and perfect for all skill levels...
This tutorial is application of MD10POT motor driver that can be use directly from the board without programming. The turntable is produce using 3D Printing method...
This article will take you through a step-by-step journey, covering everything from prepping the prints to choosing the right paints and techniques for a flawless finish...
Understanding the role of shells is vital for achieving optimal print results and ensuring the desired characteristics of the final product. The purpose of this article is to provide a comprehensive..
Modifying existing 3D models offers numerous benefits, including the ability to personalize and customize designs, save time and effort by building upon existing structures, learn and improve design..
Lithophanes are special artworks that use light and shadows to create beautiful images. Traditionally, making lithophanes required a lot of skill, but now, thanks to 3D printing..
Proper support removal is essential for achieving a clean, smooth, and professional finish on your 3D prints. It requires careful attention and the use of appropriate techniques to avoid damaging..
PLA smoothing techniques provide effective methods to minimize these lines, resulting in smoother surfaces and professional finishes. In this guide, we will explore various PLA smoothing techniques..
Cura's support blocker feature is a great tool that lets you prevent support structures from being printed in specific areas where they're not needed, saving you material, time, and effort in post-pro..
The Cura Fuzzy Skin setting is a feature that adds a unique textured surface to 3D printed objects. This setting can be a great way to add a creative and artistic touch to your 3D prints. In this arti..
Cleaning your 3D printer bed can seem daunting, but it doesn't have to be. In this article, we'll cover 4 easy ways to keep your 3D printer bed clean...
While many factors contribute to successful 3D printing, the print bed is a critical component. The print bed provides the surface on which the object is built, and its flatness and adhesion propertie..
3D printing pens offer an affordable and accessible way to experiment with 3D printing technology, making it possible for individuals and small businesses to create complex structures and shapes...
