The Hardware Interface Device (HID) is identifiable when the device is connected to the externally installed Type A USB host connector, which is derived from TinyUSB...
To build this robot, there are quite a number components and 3d printed parts are required. Hence this will be separated into two two different parts. First we will look at the components, and next we..
PREREQUISITES: This tutorial assumes that you are familiar with Arduino Boards, Arduino IDE Software, Serial Monitor, micro:bit and how to download program into micro:bit.....
Push-ups are a very useful technique to build muscles and strengthen your upper body. However, it must be done in the right way or else it may cause injuries or pain in the back or shoulders. On the o..
In this simple tutorial it is demonstrated how to interface the PCT2075 temperature sensor with Maker Pi Pico and display the value on the Sparkfun RGB LCD. The PCT2075 temperature sensor by NXP is a ..
In this tutorial we shall see how to detect the RGB color using Raspberry Pi Pico and APDS 9960 sensor. The result is then displayed on the Sparkfun RGB lcd. Basically the sensor is capable of detecti..
In this tutorial we shall see how to measure the soil moisture using Raspberry Pi Pico and Maker Soil Moisture sensor. To build this project is very straight forward as it does not require complicated..
VideoHardware PreparationFor this tutorial we will need the following componentsDCIM\101MEDIA\DJI_0277.JPGRaspberry Pi Pico Microcontroller BoardGrove - Temperature....
