![Automatic Dustbin Using REKA:BIT Automatic Dustbin Using REKA:BIT](https://static.cytron.io/image/tutorial/automatic-dustbin-using-rekabit/Rekabit-Automatic-Dustbin.jpg)
- 23 Jun 2021
- 1327
Maybe this is the first tutorial using REKA:BIT. ? So I decide to build a simple automatic dustbin. When the sensor detects an object distance of less than 10cm, the servo motor will open the cover for 5 seconds.
This video shows how automatic dustbin works with REKA:BIT.
- REKA:BIT - Simplifying Robotics with micro:bit
- Grove - Ultrasonic Ranger
- RC Servo Motor (Metal Gear)
- Aluminum 25T Servo Horn Arm (Red)
This sample program is using MakeCode. Before that you need to add the extension of "rekabit" and "grove".
![makecode](https://static.cytron.io/image/tutorial/automatic-dustbin-using-rekabit/MakeCode-1024x576.png)
สินค้าที่เกี่ยวข้อง
Discontinued
x 1 หน่วย
Discontinued
x 1 หน่วย
ไม่สามารถใช้ได้
x 1 หน่วย
ไม่สามารถใช้ได้
x 1 หน่วย
