Control and Monitor Using Blynk IoT App and micro:bit
- 20 Oct 2021
- 1060
In the previous video we have managed to display the internet time on micro:bit. This time we will try to use the Blynk IoT app to control and monitor.
This video shows how you can control the relay on and off, as well as monitor the temperature in micro:bit.
- REKA:BIT - Simplifying Robotics with micro:bit
- Grove WiFi 8266 – IoT for micro:bit and beyond
- Grove – Relay
This is MakeCode sample program. You need to edit the WiFi SSID, password and the Blynk token in the program. FYI, this program requires the extension of “esp8266 cytron”.
