Getting Started With Node-RED Using Raspberry Pi
- 05 Jan 2021
- 918
Node-RED is a programming tool for wiring together hardware devices, APIs and online services in new and interesting ways. It provides a browser-based editor that makes it easy to wire together flows using the wide range of nodes in the palette that can be deployed to its runtime in a single-click. In this tutorial, we will share how to get started with Node-RED using Raspberry Pi.
This video shows how to get started with Node-RED using Raspberry Pi.
- Raspberry Pi 4 Model B (2GB RAM)
- Phidisk Class10 MicroSD
- Official RPi USB-C Adapter
- Snap & Fit ABS Case for RPi 4B - Translucent
