![I2C LCD Using micro:bit I2C LCD Using micro:bit](https://static.cytron.io/image/tutorial/i2c-lcd-using-microbit/microbit-I2C-LCD-Featured.jpg)
- 23 May 2019
- 850
If you feel LED matrix on micro:bit is small enough to display any status, you can consider to use I2C LCD.
This video will show you how to display text on I2C LCD using micro:bit.
HARDWARE PREPARATION
![Microbit I2c Lcd Featured](https://static.cytron.io/image/tutorial/i2c-lcd-using-microbit/microbit-I2C-LCD-Featured-1024x576.jpg)
[gist https://gist.github.com/IdrisCytron/7ea454da4a8614ae7ec785e1953f37e7 /]
This is the sample code used in the video. Please install LiquidCrystal I2C library from Frank de Brabander.
สินค้าที่เกี่ยวข้อง
BreadBoard Power Stick 5V 3V3
Discontinued
x 1 หน่วย
Edge Breakout for micro:bit I/O Expansion
Discontinued
x 1 หน่วย
I2C 1602 Serial LCD for Arduino & RPI
ไม่สามารถใช้ได้
x 1 หน่วย
