![Installing OpenCV on Raspberry Pi 4B Installing OpenCV on Raspberry Pi 4B](https://static.cytron.io/image/tutorial/installing-opencv-on-raspberry-pi-4b/101539809_2336498889988330_8465344711798816768_n-1-1-1-1-1-1-1.jpg)
Image Processing is often referred to as 'Digital Image Processing' and the domain where it is commonly used is 'Computer Vision'. Make no mistake - we'll discuss these two terms and how they relate. Both the Image Processing algorithm and the Computer Vision (CV) algorithm take pictures as input; however, in image processing, the output is also an image, whereas in the computer vision output there can be some features/information about the image. There's one that we use the most, the Open CV library.
This video shows how to install OpenCV on Raspberry Pi 4B.
OR
OR
