![Play MP3 File on Maker Pi Pico Using CircuitPython Play MP3 File on Maker Pi Pico Using CircuitPython](https://static.cytron.io/image/tutorial/play-mp3-file-on-maker-pi-pico-using-circuitpython/RasPi-Pico-MP3.jpg)
- 13 Apr 2021
- 2364
CircuitPython has released a stable version for the Raspberry Pi Pico which is version 6.2.0. The latest firmware has a built-in library for audiomp3. So for this tutorial, I would like to play MP3 files using Maker Pi Pico. Ok let’s try!
This video shows how to play MP3 files on Raspberry Pi Pico / Maker Pi Pico.
- Maker Pi Pico
- Raspberry Pi Pico - Pre-soldered Headers
- Maker Pi Pico Base
- 6W Stereo USB Powered 3.5mm Jack Speaker - Black
- Grove - Mini PIR Motion Sensor
This is CircuitPython sample code to play MP3 file on GP18 when button GP20 is pressed. Please replace with your MP3 file name and duration. Refer to the video for more detail.
- CircuitPython Essentials - CircuitPython MP3 Audio
สินค้าที่เกี่ยวข้อง
THB205.41 THB191.97
6W Stereo USB Powered 3.5mm Jack Speaker-Black
THB310.23 THB289.93
Raspberry Pi Pico
THB175.00 THB163.55
Maker Pi Pico Development Board สำหรับเรียนรู้ ...
THB410.00 THB383.18
Maker Pi Pico Base (without Pico): Simplifying ...
THB307.00 THB286.92
