Program Seeeduino XIAO Using CircuitPython
- 21 Oct 2020
- 628
Python is the fastest growing programming language. It's taught in schools and universities. It's a high-level programming language which means it's designed to be easier to read, write and maintain. CircuitPython is based on Python. It is designed to simplify experimenting and learning to code on low-cost microcontroller boards. From this tutorial, you can get start with CircuitPython using Seeeduino XIAO.
This video shows how to program Seeeduino XIAO using CircuitPython.
This is CircuitPython sample program to blink an LED at pin 13 on Seeeduino XIAO.
