Raspberry Pi with PIR Sensor
In this lesson, we will learn on how to use a PIR sensor module with Raspberry Pi. It’s simple and easy project to detect a motion.
HARDWARE PREPARATION
This tutorial use :
- Raspberry Pi
- Maker Hat
- USB Micro B Cable
- Low Cost PIR Sensor Module
[gist https://gist.github.com/atifahsuad/b765eec9846105a47ca819dd3fb2c153/]
Thank you
