Robot Antenna
I have this paper robot and I want it to look fancy by adding an LED on his head. Hihi. So I decided to make this antenna and adding a sound to it using Raspberry Pi.
This is the video for this project.
HARDWARE PREPARATION
This tutorial use :
Connection | |
Speaker | Raspberry Pi : Audio Jack |
Red LED (+) | Raspberry Pi : GPIO 17 |
Red LED (-) | Raspberry Pi: GND with Resistor |
SOFTWARE
This project is using Scratch 2.0 with GPIO support.
SAMPLE CODE
THE IRON MAN
This is the image for the Iron Man paper craft. Kindly download it here.
REFERENCE :
- I took an example from this page. You can always check this page as it provides many tutorial starting from beginner to advance.
Thank you
