![Send Data to Firebase Using Raspberry Pi Send Data to Firebase Using Raspberry Pi](https://static.cytron.io/image/tutorial/send-data-to-firebase-using-raspberry-pi/RPi-Firebase-MLX90614.jpg)
- 09 Dec 2020
- 3693
Firebase (Google's platform) is a mobile-backend-as-a-service that provides powerful features for building mobile apps. It has three core services: a realtime database, user authentication and hosting. In this tutorial, we will try to explore how to send data to Firebase using Raspberry Pi.
This video show how to send sensor data to Firebase using Raspberry Pi.
- Raspberry Pi 4 (2GB)
- Raspberry Pi 4 (4GB)
- Raspberry Pi 4 (8GB)
- Phidisk Class10 MicroSD
- Maker pHAT
- MLX90614 Non-Contact Infrared Temperature Sensor
- 15W (5V/3A) USB C Adapter
This is python3 example program to read sensor data from MLX90614 and send it to the Firebase. It involves 3 libraries, you can install it through the following commands.
sudo pip3 install adafruit-blinka sudo pip3 install adafruit-circuitpython-mlx90614 sudo pip3 install pyrebase
- GitHub - pyrebase
