![USB Serial Communication Using Raspberry Pi and Microbit USB Serial Communication Using Raspberry Pi and Microbit](https://static.cytron.io/image/tutorial/usb-serial-communication-using-raspberry-pi-and-microbit/RPi-Microbit-USB-Serial.jpg)
- 05 Aug 2020
- 1056
To expand controller capability, sometimes it is necessary to communicate with other controllers. There have few common protocols in controller communication e.g. UART, I2C, SPI and etc. This tutorial will share on how to do the UART serial communication between Raspberry Pi and micro:bit through USB connection.
This video shows how to do serial communication between Raspberry Pi and micro:bit over a USB connection.
- Raspberry Pi 4 Model B (2GB)
- 16GB Micro SD Card
- Maker pHAT
- EDU:BIT Training & Project Kit for micro:bit
This is python sample program for micro:bit (top) and Raspberry Pi (bottom). You can use mu editor to program micro:bit and Thonny Python IDE to run program in Raspberry Pi.
