Write Read Data to SD Card Using Maker Pi Pico and CircuitPython
- 02 Feb 2021
- 2463
Besides MicroPython, Raspberry Pi Pico can also be programmed using CircuitPython. You can read the differences between MicroPython and CircuitPython for Raspberry Pi Pico here ? MicroPython or CircuitPython? In this tutorial, we will try to write and read the data on the SD card using Maker Pi Pico.
This tutorial shows how to write and read data to the SD card using Maker Pi Pico (Raspberry Pi Pico). It is programmed using CircuitPython.
This is the basic CircuitPython code to interface SD card using Maker Pi Pico (Raspberry Pi Pico).
