![Build Fun Piano with Ultrasonic using Maker Nano RP2040 Build Fun Piano with Ultrasonic using Maker Nano RP2040](https://static.cytron.io/image/cache/tutorial/build-fun-piano-with-ultrasonic-using-maker-nano-rp2040/Thumbnail-800x320.png)
- 08 Sep 2022
- 1155
This tutorial shows how to make a piano using an ultrasonic sensor and Maker Nano RP2040. The project is super fun and very simple to make! ??
How Does it Work?
![how does it work](https://static.cytron.io/image/tutorial/build-fun-piano-with-ultrasonic-using-maker-nano-rp2040/How-does-it-work.jpg)
![ultrasonic piano circuit diagram](https://static.cytron.io/image/tutorial/build-fun-piano-with-ultrasonic-using-maker-nano-rp2040/Ultrasonic_Piano-_Circuit_Diagram.jpg)
#define echoPin 12 #define trigPin 13 #define led1 14 #define led2 15 #define buzzer 22 // buzzer pin in Maker Nano RP2040 is 22 // defines variables long duration; // variable for the duration of sound wave travel int distance; // variable for the distance measurement void setup() { Serial.begin(9600); pinMode(led1, OUTPUT); pinMode(led2, OUTPUT); pinMode(buzzer, OUTPUT); pinMode(trigPin, OUTPUT); pinMode(echoPin, INPUT); } void loop() { // Ultrasonic Code digitalWrite(trigPin, LOW); delayMicroseconds(2); digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); duration = pulseIn(echoPin, HIGH); distance = duration * 0.034 / 2; Serial.print("Distance: "); Serial.print(distance); Serial.println(" cm"); if (distance < 5){ tone(buzzer, 523); // Play tone C digitalWrite(14, HIGH); digitalWrite(15, HIGH); delay(500); noTone(buzzer); digitalWrite(14, LOW); digitalWrite(15, LOW); delay(500); } else if (distance < 10){ tone(buzzer, 587); // Play tone D digitalWrite(14, HIGH); digitalWrite(15, HIGH); delay(500); noTone(buzzer); digitalWrite(14, LOW); digitalWrite(15, LOW); delay(500); } else if (distance < 15){ tone(buzzer, 659); // Play tone E digitalWrite(14, HIGH); digitalWrite(15, HIGH); delay(500); noTone(buzzer); digitalWrite(14, LOW); digitalWrite(15, LOW); delay(500); } else if (distance < 20){ tone(buzzer, 698); // Play tone F digitalWrite(14, HIGH); digitalWrite(15, HIGH); delay(500); noTone(buzzer); digitalWrite(14, LOW); digitalWrite(15, LOW); delay(500); } else if (distance < 25){ tone(buzzer, 783); // Play tone G digitalWrite(14, HIGH); digitalWrite(15, HIGH); delay(500); noTone(buzzer); digitalWrite(14, LOW); digitalWrite(15, LOW); delay(500); } else if (distance < 30){ tone(buzzer, 880); // Play tone A digitalWrite(14, HIGH); digitalWrite(15, HIGH); delay(500); noTone(buzzer); digitalWrite(14, LOW); digitalWrite(15, LOW); delay(500); } else if (distance < 35){ tone(buzzer, 987); // Play tone B digitalWrite(14, HIGH); digitalWrite(15, HIGH); delay(500); noTone(buzzer); digitalWrite(14, LOW); digitalWrite(15, LOW); delay(500); } else { noTone(buzzer); digitalWrite(14, LOW); digitalWrite(15, LOW); } }
Project Complete
![screenshot](https://static.cytron.io/image/tutorial/build-fun-piano-with-ultrasonic-using-maker-nano-rp2040/Screenshot.png)
สินค้าที่เกี่ยวข้อง
LED 3mm Yellow
THB0.85 THB0.79
x 1 หน่วย
Maker Nano RP2040: Simplifying Projects with Ra...
ไม่สามารถใช้ได้
x 1 หน่วย
3V-5.5V SR04P Ultrasonic Ranging Module
ไม่สามารถใช้ได้
x 1 หน่วย
