![Build Otto DIY Robot Using Maker Pi RP2040 Build Otto DIY Robot Using Maker Pi RP2040](https://static.cytron.io/image/tutorial/build-otto-diy-robot-using-maker-pi-rp2040/otto.jpg)
Build an Otto DIY robot Using Maker Pi RP2040. This board comes with a dual-channel DC motor driver, 4 servo motor ports, and 7 Grove I/O connectors. With this board, we can build the robot easily and program it using Arduino IDE.
Watch this video to know more about it.
You can download the stl file here.
Software Preparation
This is a summary of the steps. For more details, please refer to the video.
- Download and install the latest version of Arduino IDE software.
- Add the json link ? https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json and install Raspberry Pi Pico/RP2040 board.
https://gist.github.com/suadanwar/33d076977dda49fde2b3c164361abed2
Reference
สินค้าที่เกี่ยวข้อง
Maker Pi RP2040 : Simplifying Robotics with Ras...
ไม่สามารถใช้ได้
3V-5.5V SR04P Ultrasonic Ranging Module
ไม่สามารถใช้ได้
Analog Micro Servo 9g (3V-6V)
ไม่สามารถใช้ได้
