Control Solenoid Door Lock using Relay on Arduino
Hi guys! Do you know how to control a 12VDC solenoid door lock using a relay? With a simple circuit connection, now you can use a solenoid door lock for your project.
Watch this video for more info on How To Control A 12VDC Solenoid Door Lock Using A 5V Relay on Arduino. You'll also learn the difference between normally open and normally closed relay connections in this video.
Arduino
[gist https://gist.github.com/suadanwar/57a99ad7de1ef474fb4048eb39a50727/]
Thank you
Thank you for reading this tutorial and we hope it helps your project development. If you have any technical inquiries, please post at Cytron Technical Forum.
