If you are not familiar with Raspberry Pi, you can use Arduino to display text on dot matrix using Blynk app. For me, this tutorial is intermediate level, so, you may need to refer following tutorial first.
This video shows how to display text message on dot matrix using Blynk App and Arduino.
This is sample code used in the video. 1st code (top) is for ESP8266 WiFi Shield and the 2nd code (botton) is for Maker UNO. Please replace your Blynk auth token, WiFi SSID and password.
[gist https://gist.github.com/IdrisCytron/cf4a10823755355285d37a2baec9717d/]
THB421.80 THB394.21
ไม่สามารถใช้ได้
ไม่สามารถใช้ได้
ไม่สามารถใช้ได้
