NTP Clock
- Abdul Salam A Haris
- 06 Jul 2023
- 558
This guide will show you how to connect to the internet and get internet time using Raspberry Pi Pico W with your Robo Pico.
Note: This IoT related project is only applicable if you are using Raspberry Pi Pico W but NOT Raspberry Pi Pico.
1. While your Robo Pico is connected to your computer, open your editor software (for example Thonny). Select the code.py file in your drive.
3. Flash the codes to your Raspberry Pi Pico / Pico W. And your CIRCUITPY drive should look like this:
Library file(s) required:
adafruit_ntp.mpy
File(s) required:
settings.toml
In the 'setting.toml' file, you will see lines like these:
CIRCUITPY_WIFI_SSID = "your-ssid-here"
CIRCUITPY_WIFI_PASSWORD = "your-ssid-password-here"
Simply replace 'your-ssid-here' with the name of your WiFi network, and 'your-ssid-password-here' with your WiFi password.
Advanced Code: NTP Alarm Clock
You can make your Robo Pico into your alarm clock and display your current clock on the OLED Display.
1. Make sure to copy this code including the file inside 'ntp-clock-alarm' into your CIRCUITPY drive.
2. Flash the codes to your Raspberry Pi Pico / Pico W. And your CIRCUITPY drive should look like this:
adafruit_ntp.mpy, adafruit_framebuf.mpy, adafruit_ssd1306.mpy, neopixel.mpy, simpleio.mpy
File(s) required:
font5x8.bin, settings.toml
