![I2C Communication Between Raspberry Pi and Arduino I2C Communication Between Raspberry Pi and Arduino](https://static.cytron.io/image/tutorial/i2c_communication-raspberry-pi-arduino/I2C-Pi-Arduino-HD.jpg)
- 25 Sep 2018
- 713
Besides controlling I2C modules, like display and sensors, I2C communication also can be implemented between 2 controllers. For example between Raspberry Pi and Arduino. The different compare to I2C module is, we need to create our own data protocol. So this tutorial will show you how to communicate between Raspberry Pi and Arduino Using I2C.
This video will show you how to communicate between Rasapberry Pi and Arduino Using I2C.
ITEM USED IN THE VIDEO
This is the sample code for Arduino and Raspberry Pi used in the video.
[gist https://gist.github.com/IdrisCytron/5fd2578fb9f65ceca5735b48eaefbfa0/]
References
- Controlling an Arduino from a Pi3 using I2C
- i2c python documentation
- Raspberry Pi SPI and I2C Tutorial
- Master Writer/Slave Receiver
สินค้าที่เกี่ยวข้อง
ไม่สามารถใช้ได้
ไม่สามารถใช้ได้
