Lesson 3 : Camera
- Abdul Salam A Haris
- 09 Mar 2023
- 521
The official Raspberry Pi Camera Module is compatible with the CM4 Maker Board. It only needs to be connected to the CSI camera port in order to take clear pictures and videos.
Figure 1: Raspberry Pi Camera Module.
To use the official Raspberry Pi Camera Module we need to download the corresponding blob file.
Run the following command from the terminal in order to use them.
sudo wget https://datasheets.raspberrypi.com/cmio/dt-blob-cam1.bin -O /boot/dt-blob.bin
Figure 2: The output from on Raspberry Pi terminal.
Reboot the CM4 to load the new dt-blob.bin file.
Next, you need to configure the legacy camera:
sudo raspi-config
Figure 3: raspi-config.
Then, select the Interface Options, and enable the Legacy Camera support.
Figure 4: Enable Legacy Camera Support.
Reboot the CM4 to apply the change.
If you want to save the pictures or videos on the Desktop directory instead root directory, you can use this command:
cd Desktop/
You can test the camera using this command:
Enter this command to record a 5-second video:
raspivid -o testvideo.h264 -t 5000
You should get the image and video saved in your current directory.
Figure 5: Image and video file.
อุปกรณ์ฮาร์ดแวร์
RPi Compute Module 4 with Wireless 4GB RAM Lite
THB2,454.75 THB2,294.16
Raspberry Pi 8MP Camera Module V2
THB700.00 THB654.21
CM4 Maker Board and Kits
ไม่สามารถใช้ได้
