Piano with Maker UNO
I have a nephew age 10 years old. I tried to make electronic looks easy and fun to him. Since he really like to play a music instrument, I made this small piano for him so that he can learn piano and electronics at the same time. I share this with the hope that you can also enjoy this with your loved one <3
HARDWARE PREPARATION
This tutorial use :
  1. Maker UNO
  2. Push Button
  3. Breadboard Jumper Wire Kit
  4. Male to Male Jumper Wire
  5. Breadboard
  6. Micro B USB
CONNECTION
Maker UNO : GNDBreadboard GND
Maker UNO : Pin 3Push Button : 1 (C)
Maker UNO : Pin 4Push Button : 2 (D)
Maker UNO : Pin 5Push Button : 3 (E)
Maker UNO : Pin 6Push Button : 4 (F)
Maker UNO : Pin 7Push Button : 5 (G)
Maker UNO : Pin 9Push Button : 6 (A)
Maker UNO : Pin 10Push Button : 7 (B)
*Another leg of the Push Button is connected to the GND of Breadboard
Figure 1 : The hardware connection for piano
Figure 2 : Piano
SAMPLE CODE
[gist https://gist.github.com/atifahsuad/d0cb71a4796fd779db2a289760e49d45/]
Thank you
