![TinyML on Arduino using Edge Impulse TinyML on Arduino using Edge Impulse](https://static.cytron.io/image/tutorial/tinyml-on-arduino-using-edge-impulse/TinyML-on-Arduino.jpg)
- 02 Sep 2021
- 2008
Edge Impulse is a platform that allows us to build projects related to machine learning on microcontrollers. This tutorial will be divided into a few parts, and we will update accordingly.
Part 1 - Link the board to Edge Impulse
Part 2 - Data acquisition
*Note: I'm having a problem where the microphone on the Arduino board doesn't seem to record after more than 2 attempts. If you are having the same problem, try to reset the Arduino board, and reconnecting to the Edge Impulse.
Part 3 – Train ML Model
In part 3, we will train the ML model based on the data that we collected before. Later we will deploy on the Arduino board.
Part 4 – Control LED color with voice
In part 4, we will program the Arduino board based on the trained ML model. Then we will edit the program to control the LED color using voice.
This is the sample program for Arduino to control LED color using voice.
- Edge Impulse with the Nano 33 BLE Sense
- Edge Impulse: Arduino Nano 33 BLE Sense
- Introduction to Embedded Machine Learning
สินค้าที่เกี่ยวข้อง
Arduino Nano 33 BLE Sense with Headers
Discontinued
