WiFi Neopixel RGB LED using CircuitPython
- 26 Apr 2022
- 854
I plan to add a light source to my video or live and this light can change colors. I have a NeoPixel 8x32 LED Panel, flexible type. For microcontrollers, I haven't decided yet, but it definitely supports CircuitPython.
Part 1: Design and 3D Print
This is the list of items used in the video
- Maker Pi Pico
- USB Micro B Cable
- ESP8266 ESP-01 WiFi Serial Transceiver Module
- NeoPixel 8x32 LED Panel
- Artillery Hornet 3D Printer
3D Files
You can download the STL files from Thingiverse: https://www.thingiverse.com/thing:5380104
Part 2: Wiring, IoT Platform and Coding
- adafruit_espatcontrol
- adafruit_minimqtt
- adafruit_io
- adafruit_requests.mpy
- neopixel.mpy
- CircuitPython Essentials: CircuitPython NeoPixel
- Adafruit IO Basics: Color
