Lighting Up the RGB LED
- 08 Aug 2024
- 232
This guide will show you how to light up the RGB LED on your MOTION 2350 Pro.
The figure below shows the GPIO for each of the on-board status RGB LEDs.
3. Flash the codes to your MOTION 2350 Pro. And your CIRCUITPY drive should look like this:
Library file(s) required:
neopixel.mpy
