Blink
- 08 Aug 2024
- 268
This guide will show you how to light up the LEDs on your MOTION 2350 Pro.
The figure below shows the GPIO for each of the on-board status LED.
3. Flash the codes to your MOTION 2350 Pro. And your CIRCUITPY drive should look like this (no lib file is used):
