GETTING STARTED WITH MAKER NANO RP2040 AND ARDUINO IDE
- 08 Feb 2022
- 1352
In this tutorial we shall see how to program the Maker Nano RP2040 using Arduino IDE
Steps
- The first step before we can program the Maker Nano RP2040 using the Arduino IDE is add the board to the IDE environment. To do this, copy the link below and paste it in the Additional Board Manager inside the preferences window.
https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json
Copy and paste the link above into the additional board manager URLs, as shown in the figure below
Next, go to the Tools, choose Board and click 'Board Manager
Once the Boards Manager is open, type "PICO" in the search bar and hit enter. And choose the "Raspberry Pi Pico/RP2040. If previously you have installed it, you may choose to update to latest version.
Once the installation is successful, we are ready to program our board. The next step would be to choose the correct board. To do this, go to Tools --> Board --> Raspberry Pi RP2040 Boards and choose "Cytron Maker Nano RP2040"
And the next step is to choose the correct port that the Maker Nano RP2040 is connected to. Refer to figure below
But before connecting the Maker Nano RP2040 for the first time to the PC, need to hold the BOOT button pressed while connecting the USB cable. As shown in the figure below. Once done we can burn or flash our first program into the board.
The first program that we would like to do is the classic blink program. The code for the first program is as shown in the next section.
void setup() {
pinMode(7,OUTPUT);
void loop() {
digitalWrite(7, HIGH);
delay(500);
digitalWrite(7, LOW);
delay(500);
Outcome
