![Chapter 1: EDU PICO Tag-Controlled Music Box Chapter 1: EDU PICO Tag-Controlled Music Box](https://static.cytron.io/image/tutorial/huskylens-edupico-chapter-1/7.png)
- Solehin Rizal
- 06 Jun 2024
- 117
Recognize a specific tag and trigger the EDU PICO buzzer to play a corresponding song or melody. Create different tags for different melody.
Get ready to create a music box controlled by unique tags! In this chapter, you'll learn:
Tag Recognition with HuskyLens : Explore how HuskyLens identifies specific tags and translates them into commands.
Playing Tone Music with EDU PICO : Discover how to control buzzer playback on your EDU PICO based on recognized tags.
Tutorial Video
Tutorial step
Step 1 : Learning the Tag
Obtain the unique tag from the provided source here.
Note: HuskyLens can only detect default tags programmed inside it and cannot detect other tags like QR codes .
You can start with learning 3 tag first.
Step 2 : Code
Copy the provided code and run it on your EDU PICO.
Step 3 : Tag Testing
Take the learned tag and test it with the program.
อุปกรณ์ฮาร์ดแวร์
EDU PICO with AI Kit (Pico W included)
THB4,901.89 THB4,581.21
