Measure Distance With Maker Nano RP2040 And Ultrasonic Sensor With TFT Display
- 11 Mar 2022
- 1316
In this tutorial we shall see how to interface Maker Nano RP2040 with HC-SR04P and TFT 1.44". Ultimately to measure the distance and display it on the tft display.
Building The Circuit
- The circuit for this tutorial is constructed on a breadboard with jumper wires. The connection between the Maker Nano RP2040 and Ultrasonic Sensor HC-SR04P and Maker Nano RP2040 with 1.44' TFT display is as shown in below figure
The code for this tutorial is as shown below. Make sure to download the necessary library from the library manager. The "Ultrasonic.h" library can be downloaded from the Cytron GitHub page.
#include // Core graphics library
#include // Hardware-specific library for ST7735
#include // Hardware-specific library for ST7789
#include
#include
#include
#include "Ultrasonic.h"
Ultrasonic ultrasonic(2,3);
#define TFT_CS 10
#define TFT_RST 7 // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC 9
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
int x;
void setup() {
tft.initR(INITR_144GREENTAB); // Init ST7735R chip, green tab
tft.fillScreen(ST77XX_BLACK);
tft.drawRect(0, 0, 128, 128, ST7735_WHITE);
tft.drawRect(1, 1, 126, 126, ST7735_WHITE);
welcomeMessage();
sensor();
void loop( ) {
tft.setCursor(40, 90);
tft.setTextColor(ST77XX_BLACK);
tft.setFont(&FreeMonoBold18pt7b);
tft.fillRect(32, 60, 50, 100, ST7735_WHITE);
tft.println(ultrasonic.Ranging(CM));
tft.setCursor(40, 120);
tft.println("CM");
delay(100);
void welcomeMessage() {
tft.setTextWrap(false);
tft.setCursor(7, 10);
tft.setTextColor(ST77XX_RED);
tft.setFont(&FreeMonoBold9pt7b);
tft.setTextSize(1);
tft.println("MAKER NANO");
tft.setCursor(30, 30);
tft.println("RP2040");
tft.setCursor(9, 45);
tft.println("ULTRASONIC");
tft.setCursor(4, 60);
tft.println("SENSOR WITH");
tft.setCursor(5, 75);
tft.println("TFT DISPLAY");
tft.drawRect(8, 90, 105, 11, ST7735_WHITE);
for(x=0;x<110;x=x+10){
tft.fillRect(10, 92, x, 7, ST7735_BLUE);
tft.setCursor(30, 115);
tft.fillRect(10, 104, 40, 20, ST7735_BLACK);
tft.setTextColor(ST77XX_GREEN);
tft.println(x);
tft.setCursor(60, 115);
tft.println("%");
delay(800);
void sensor(){
tft.fillScreen(ST77XX_WHITE);
tft.drawRect(0, 0, 128, 128, ST7735_YELLOW);
tft.drawRect(1, 1, 126, 126, ST7735_YELLOW);
tft.setCursor(5, 30);
tft.println("DISTANCE :");
Outcome
